I was unable to convert a lot of my .avi files so I went to gspot and it said all my codecs were installed but that there was this error.....
failed to connect Output pin 0x0093ae4c ["Stream 00"] on AVI Splitter to input pin0x0093d38c ["In"] on fliter 0x0029a394f["ffdshow raw video filter"]. ConnectDirect[] failed. Error: 0x80040207: [unknown]
I've got to get all my .avi's compressed and off my computer because it needs to be restored. I need help. Open to all suggestions.
0x80040207 means that the DirectShow couldn't find a suitable set of filters to connect your AVI Splitter's output to the ffdshow input.
Most probably, you need an additional filter that can convert your AVI format into a format that ffdshow can use.
What format are your AVIs?
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Panasonic DMR-ES35V "Self-Check Failed," refuses to run
By MattOKC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jul 2010, 18:50 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Broken AVI Files after data recovery "FFmpegSource: Couldn't find stream information"
By fixavifile in forum Newbie / General discussionsReplies: 8Last Post: 28th Jan 2010, 04:24 -
ATI AIW 9600XT, "TV failed to initialize the video" problem...
By etecnifibre in forum Capturing and VCRReplies: 11Last Post: 20th May 2008, 16:08
